1.6SR AKL korekty STFT LTFT - gdzie w VAG-COM ?
Pytanko mam do osób obeznanych w VAG-COM.
Gdzie, na jakim kanale można sprawdzić korekty STFT/LTFT ??
Auto Seat Toledo 2000r, silnik typ AKL, sterownik Simos. Kanał 30 i 31 jest niedostępny. Znalazłem jakieś parametry na kanale 10, 11 i 99 ale nie mam pewności czy to jest to czego szukam grinser006.gif
Poniżej opisy bloków pomiarowych dla tego sterownika
; 06A-906-019-XX
; Created by Kim Andersen:[email protected]
; Engine code: AEH-AKL Golf 1998>,Bora 1999>
; ECU Number : 06A-906-019
; Engine type: 1.6 I R4/2V SIMOS HS 2272
; Coding:04000
; Documentation used:"Erwin WorkShop Manual Golf 1998>,Bora 1999>
; Simos injection and ignition system"
0,0,Measured value blocks(Engine running at idle speed)click for details
0,1,Intake air temperature , 84-158 = 15-71°Celius
0,2,Engine control unit supply voltage, 98-147 = 10-15 Volt
0,3,Coolant temperature , 170-211 = 80-110°Celius
0,4,Air mass drawn in , 14-30 = 76-164 mg/lift
0,5,Lambda probe voltage , 0-50 = 0.0-1.0 Volt
0,6,Lambda learnt value at idling , 0-100 = -0.8-0.8 ms
0,7,Operation condition of Lanbda control-See measured value block 99
0,8,Throttle valve angle , 4-12 = 1.9-5.7°
0,9,Injection period , 2-4 = 2-4.1 ms.
0,10,Engine speed (idling speed) , 23-27 = 760-880 RPM
1,0,Basic functions-Click for details
1,1,Engine speed,,760-880 rpm
1,2,Coolant,Temperature,80-110°Celius
1,3,Lambda,voltage,0.00-1.00 Volt
1,4,TBA valve,00000010,see lable file for details
;xxxxxxxx
;1 Fault identified by self-diagnosis
; 1 Signal from automatic gearbox
; 1 Air conditioner switched on
; 1 Idling speed switch open
; 1 Fault in Lambda control
; 1 Throttle valve open (angle check)
; 1 Engine running
; 1 Coolant temperature less than 80 °Celius
2,0,Basic Functions-Click for details
2,1,Engine speed,,760-880 rpm
2,2,Airflow,(engine load),76-164 mg/H
2,3,Road speed,
2,4,Engine,operating mode,see label file
;xxxx
;1 Overrun
; 1 Idling
; 1 Part throttle
; 1 Full throttle
3,0,Basic functions-Click for details
3,1,Engine speed,,760-880 rpm
3,2,Airflow, (engine load),76-164 mg/H
3,3,Throttle valve, angle, 1.9°-5.7°
3,4,Throt.valve, posi.duty cycle, -100-100 %
4,0,Basic functions-Click for details
4,1,Engine speed,, 760-880 rpm
4,2,Airflow,(engine load), 76-164 mg/H
4,3,Injection,period, 2.0-4.10 ms
4,4,Air mass, drawn in, 1.8 - 3.2 g/s
5,0,Basic functions-Click for details
5,1,Engine Speed,,760-880 rpm
5,2,ECU,Voltage Supply, 10-15 Volt
5,3,Coolant,Temperature, 80-110°Celius
5,4,Intake air,Temperature, 15-71°Celius
6,0,Altitude adaption-Click for details
6,1,Engine speed,, 760-880 rpm
6,2,Airflow,(engine load), 76-164 mg/H
6,3,Throttle valve, angle, 1.9°-5.7°
6,4,Altitude,correction factor,0.9-1.1
7,0,Idling adjustment-Click for details
7,1,Throttle valve, angle,1.9°-5.7°
7,2,Idling learnt, value,0.95-1.05
7,3,Idling learnt, value,0.95-1.05
7,4,Engine,operating mode,see label file
;xxxx
;1 Overrun
; 1 Idling
; 1 Part throttle
; 1 Full throttle
8,0,Idling stabilitation-Click for details
8,1,Engine speed,Actual,760-880 rpm
8,2,Engine speed,specified,800-840 rpm
8,3,Idling control,,10-15 %
8,4,Amount of,air drawn in,1.0-3.2 g/s
9,0,Idling air requirements-Click for details
9,1,Idling,control,10-15 %
9,2,Throttle valve, status,see label file
;xxxxxxxx
;0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 1 Fault has occurred during adaption
; 1 No current supply to throttle valve
; 1 Battery voltage too low (below 8V)
; 1 Idling switch open
9,3,Coolant,temperature,80-110°Celius
9,4,Engine speed,,760-880 rpm
10,0,Lambda control and activated charcoal filter system-Click for details
10,1,Lambda, regulation,+25 to -25 %
10,2,Lambda probe,Voltage,0.00-1.00 Volt
10,3,Activated charcoal, valve 1 Duty Cycle,0-20 %
10,4,Lambda correction, Tank venting active,-20-2 %
11,0,Lambda learning values-Click for details
11,1,Injection,Period,2.00-4.10 ms
11,2,Lambda learnt, value idling,-0.1-1.0 ms
11,3,Lambda learnt, value part load,0.9-1.15 ms
11,4,Cond.tank, breather valve,see label file
;xxxxxxxx
;0 Vacant
; 1 Transition to vapour content check via fuel tank breather valve
; 1 Transition to fuel tank breather valve minimum operating level
; 1 Transition to fuel tank breather valve closure
; 1 Vapour content check via fuel tank breather valve
; 1 Fuel tank breather valve operating normally
; 1 Fuel tank breather valve minimum operating level
; 1 Fuel tank breather valve closed
12,0,Lambda control-Click for details
12,1,Engine speed,760-880 rpm
12,2,Airflow,(engine load),76-164 mg/H
12,3,Lambda,regulation,-25% to +25 %
12,4,Lambda probe, Voltage,0.00-1.00 volt
13,0,Fuel consumption-Click for details
13,1,Engine speed,,760-880 rpm
13,2,Airflow, (engine load),76-164 mg/H
13,3,Road speed,,0 km/h
13,4,Fuel consumption,,0.50-2.00 l/h
14,0,Knock control
14,1,Cyl 1,ign.angle retard,0.0°CA
14,2,Cyl 2,ign.angle retard,0.0°CA
14,3,Cyl 3,ign.angle retard,0.0°CA
14,4,Cyl 4,ign.angle retard,0.0°CA
15,0,Knock control
15,1,Engine speed,,760-880 rpm
15,2,Airflow,(engine load),76-164 mg/H
15,3,Cyl 1,ign.angle retard,0.0°CA
15,4,Cyl 2,ign.angle retard,0.0°CA
16,0,Knock control
16,1,Engine speed,,760-880 rpm
16,2,Airflow,(engine load),76-164 mg/H
16,3,Cyl 3,ign.angle retard,0.0°CA
16,4,Cyl 4,ign.angle retard,0.0°CA
17,0,Knock control - Knock Sensor Voltages
17,1,Cyl 1,knock sensor,0.400-1.300 Vpt
17,2,Cyl 2,knock sensor,0.400-1.300 Vpt
17,3,Cyl 3,knock sensor,0.400-1.300 Vpt
17,4,Cyl 4,knock sensor,0.400-1.300 Vpt
18,0,Torque reduction for automatic gearbox
18,1,Engine speed,,760-880 rpm
18,2,Airflow,(engine load),74-164 mg/H
18,3,Ign.timing retard,gearbox cut-in,0.0°CA
18,4,Ignition timing,,6-14°BTDC
19,0,Operation condition
19,1,Engine speed,,760-880 rpm
19,2,Selector lever, pos.(0 or 1),0
19,3,Air conditioner,(0 or 1),0
19,4,Operation condition,see label file
;xxxxxxxx
;0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 1 Clutch pedal switch operated
; 1 Power steering pressure switch F88 activated
; 1 A/C compressor switched on
20,0,Lambda control operating condition
20,1,Engine speed,,760-880 rpm
20,2,Airflow,(engine load),76-164 mg/H
20,3,Coolant,Temperature,80-110°C
20,4,Operation condition,see label file
;xxxxxxxx
;1 Fault recorded in memory
; 0 Not allocated
; 0 Not allocated
; 1 Restricted operation mode
; 1 Lambda control at limit
; 1 Lambda control switched on
; 1 Lambda probe functioning
; 1 Mixture status: 1= Rich mixture 0= Lean mixture
21,0,Throttle valve control adaption - Click for details
21,1,Throt.valve,control adaption,see label file;xxxxxxxx
;0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 0 Not allocated
; 1 Fault has occured during adaption
; 1 No current supply(duty cycle=0)
21,2,Throt.valve,min.position,70-100 %
21,3,Throt.valve,emerg.run.posi.,67-100 %
21,4,Throt.valve,max.position,0-20 %
22,0,Position of camshaft in relation to crankshaft
22,1,Engine speed,,760-880 rpm
22,2,Airflow,(engine load),76-164 mg/H
22,3,No.teeth,on Crk.sender,(- to +) 26-30
22,4,No.teeth,on Crk.sender,(+ to -) 86-90
57,0,Idling speed stabilisation-Air Compressor pressure signal-Click for details
57,1,Engine speed,Actual,,760-880 rpm
57,2,Idling speed,Specified,Compressor: ON 800-920 /OFF 760-880 rpm
57,3,A.C. Compres.,Mode,ON or OFF
57,4,G65, Duty Cycle,Compressor: ON 10-70% /OFF 1-5%
66,0,Cruise control system-Click for details
66,1,Road speed,(actual),0 km/h
66,2,Brake clutch CCS, switch position,System 1000 For more see lable file
;xxxx
;1 Cruise control system available
; 1 Clutch pedal depressed/autom.gearbox always 1
; 1 Brake depressed or for autom.gearbox
; selector lever in "P" position and ignition switched on (engine stationary)
66,3,Road speed,(specified),0 km/h
66,4,Cruise Control,Swith Position,0000=0ff/0001=on For more see lable file
;xxxx
;1 Resume speed,accelerate (CCS sliding switch at RES)
; 1 save speed/delay (SET button pressed)
; 1 CCS temporarily switched off{By brake or clutch),memory saved
; 1 CCS switched On
98,0,Matching throttle valve control part
98,1,Throttle Position,Sensor Voltage,3.70-4.75 Volt
98,2,Throttle Position,Actuator Voltage,2.28-4.75 Volt
98,3,Operating Mode,,00000000
98,4,Basic Setting,Status,00
99,0,Lambda regulation
99,1,Engine speed,,760-880 rpm
99,2,Coolant,temperature,80-110°C
99,3,Lambda, regulation,-25 to +25 %
99,4,Lambda,Operating condition,0xxx011x
