Zagadka bez obrazka....
Quote:
price $2 000 000 USD
engine Modified V10 w/Low Compression Pistons
position Mid Longitudinal
aspiration Twin Turbochargers
valvetrain DOHC 4 Valves per Cyl
fuel feed Sequential Multi-Point Fuel Injection
displacement 5733 cc / 349.8 cu in
bore 98 mm / 3.86 in
stroke 76 mm / 2.99 in
power 745.7 kw / 1000 bhp @ Not Available rpm
hp per litre 174.43 bhp per litre
bhp/weight 724.64 bhp per weight
drive wheels RWD w/ASR 5.7, LSD
body / frame Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame
front brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
f brake size 400 mm / 15.7 in
rear brakes Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
r brake size 400 mm / 15.7 in
front wheels F 48.3 x 25.4 cm / 19 x 10 in
rear wheels R 50.8 x 33.0 cm / 20 x 13 in
front tire size 275/30-19
rear tire size 345/25-20
steering Rack & Pinion w/Power Steering
f suspension Double Wishbones w/Inboard Springs & Dampers
r suspension Double Wishbones w/Inboard Springs & Dampers
weight 1380 kg / 3042 lbs
transmission 6-Speed Race-Sourced Transaxle
gear ratios Not Available36:1
0 - 60 mph Not Available seconds
> Vector? Ale czy nie za drogi?
vector miał 8 cylindrów.. i był bardzo drogi
