sony cdx-s2200 i XM-502Z i ? co dalej
Co sadzicie o polaczeniu tego w calosc ?
cdx-s2200
speaker impedance 4-8ohm
4x50W i preout na tylne
SSIR-EXA Tuner / ABC (Automatic Bandwidth Control), Station Presets: FM / MW / LW (18/6/6), BTM (Best Tuning Memory), RDS EON, CD: CD-R / CD-RW Playback capability, MP3 Playback capability, ID3 Tag (Track-, Artist-, Album name), CD Text, Frequency Response 10-20,000 Hz, Signal to Noise Ratio 120dB, Repeat / Shuffle, S-MOSFET output stage, Output Power (DIN 45324, 4 ohm) 4x 26W, Max. Output Power (1kHz, 4 ohm) 4x 50W, EQ-3 (3 Band Equalizer), Pre-amp Output, Max. Pre-amp output level 2V, Sub Output, Low Pass Filter, Sub Volume Control, Segment LCD display, Display Dimmer, Key Illumination: red, Safety Commander Interface: 3.5 mm jack, Sensor for IR Commander, Removable Front Panel. Integrated Clock: 24 h, Telephone Attenuator, ISO Connector: supplied Adaptor, Installation Angle 0-45 degrees, Dimensions (WxHxD in mm) approx. (178x50x179), Safety Commander optional at extra cost RM-X4S, IR Card Commander optional at extra cost RM-X114.
wzmacniacz XM-502Z:
info_1
cena ok 200zl nowka
moje pytania
1) czy to dobre dla siebie ?
2) jesli tak to jaki bass do tego ( w sumie chcialbym aby to byl wzmacniacz do tuby
3) jesli nie tuba, to jakie glosniki ( choc wole rozwiazanie z pkt 2 )
4) jesli zly wzmacniacz to jaki do tego radia aby na koncu posadzic jakas tube/bass ?
