pomocy bląd P-1596 SPEED CONTROL SWITCH ALWAYS HIGH W JEEP
WITAM,
POMOZCIE PROSZĘ..DZIS PODCZAS JAZDY ZAPALIL MI SIE CHECK SILNIKA,WYWALILO MI BLĄD P-1596 W JEEP GRAND CHEROKIEE LIMITED..
COŻ TO MOŻE BYĆ???CZY NA TYM MOZNA JEZDZIC???CO Z TYM ZROBIĆ???
Wersaliki to krzyk - wiesz ?
http://www.wjjeeps.com/faultcodes.htm
Generalnie:
Speed control switch input above maximum acceptable voltage. Check the bottom row of pins in the C200 connector for contamination If the bulkhead (C200 connector in some applications as DN model) is contaminated by moisture, the speed control may not set. This may occur after driving the vehicle in rain or by washing the vehicle. Also if the rear heater water pump is leaking, as on a DN model with rear heat, the C200 could be contaminated with anti-freeze. Once connector is cleaned from antifreeze contamination, review water pump for potential leak and repair as necessary. If there is water intrusion into the connector, dry the connector and repair area that is allowing water into the connector. This area is the source of many speed control complaints. Various fault codes can be set due to contamination of this connector.
Czy można jeździć - niewiem -
