Kia Sorento 3.5 v6
Zdecydowałem się na zakup Sorento z rocznika ~2005r., miał ktoś z Was doświadczenie z modelem? Na co zwracać uwagę przy oględzinach? Jakieś typowe bolączki?
Z tym silnikiem to raczej import z USA. Malo tego u nas a jak juz jest to najczesciej z dieselem. Nie wiem jak gaz trzeba znalezc kogos kumatego ale znow malo ich jezdzi wiec i o kumatego trudno zlosnik.gif
> trudno
A to nie ten sam motor co w np w Rav4?
he G6AU and G4HC (both also called the 3.5 D ) are the large 3,497 cc (3.497 L; 213.4 cu in) versions of the Sigma engine. Bore and stroke are both larger at 93 mm (3.7 in) and 85.8 mm (3.38 in) respectively. Output is 200 hp (149 kW) at 5500 rpm and 214 lb·ft (290 N m) at 4800 rpm for the older G6AU V6 and 217 hp (162 kW) at 5500 rpm and 232 lb·ft (314 N m) at 3500 rpm for the new G4HC Sigma.
The 3.5 D has a cast iron engine block and aluminum DOHC cylinder heads. It uses MFI fuel injection, has 4 valves per cylinder, and features forged steel connecting rods. It is designed to run on "regular" unleaded gasoline rather than the premium fuel used in many other high-output V6 engines.
The US-market version produces 194 hp (145 kW) at 5500 rpm with 219 lb·ft (297 N m) of torque at 3500 rpm. It was introduced with the Kia Sedona minivan in 2001.
Applications(US)
2002-2005 Hyundai XG350
2003-2006 Hyundai Santa Fe
Applications(Korea)
1999-2005 Hyundai Dynasty
2002-2007 Hyundai Terracan
2002-2005 Hyundai Grandeur
Applications(Kia)
2001-2005 Kia Sedona
2004-2006 Kia Amanti
2003-2006 Kia Sorento
This Engine is no longer used by Kia/Hyundai automotive group.
Zrodlo wiki + wlasne.
