Silnik 1.8 2H0
Co o nim więcej wiadomo?
Doczytałem, że to może być to A18XER (2H0): 1.8 L (1796 cc): DCVCP, TwinPort, 10.8:1 compression.
i dalej:
DCVCP
A variant of 1.8L Family 1 engine featuring Euro IV compliancy, DCVCP (Double Continuous Variable Cam Phasing technology, a variant of VVT) and integrated catalytic converter, entered production in Spring 2005. It was based on the lighter cast-iron block, although there's no TwinPort in this version.
An updated 1.6 L TwinPort engine with DCVCP was introduced in 2006.
In 2011, the new Gen III block has been introduced which features DCVCP, TwinPort and piston cooling by oil jets, as well as higher compression ratio.
These engines are manufactured at Szentgotthárd, Hungary, Bupyeoung, Korea and Toluca, Mexico.
A18XER: 1.8 L (1796 cc): DCVCP, 80.5 mm (3.17 in) bore, 88.2 mm (3.47 in) stroke, 10.5:1 compression, 140 hp (103 kW) and 129 lb·ft (175 Nm) of torque, combined fuel economy 7.0 L/100 km (40 mpg-imp; 34 mpg-US)
A16XER: 1.6 L (1598 cc): DCVCP, TwinPort, 79 mm (3.11 in) bore, 81.5 mm (3.21 in) stroke, 10.5:1 compression, 115 hp (85 kW) @ 6000 rpm, 155 N·m (114 lbf·ft) @4000 rpm, combined fuel economy 6.3 L/100 km (45 mpg-imp; 37 mpg-US).
A18XER (LUW): 1.8 L (1796 cc): DCVCP, TwinPort, 10.5:1 compression, 138 hp (102.9 kW; 139.9 PS) @6300 rpm, 125 lb·ft (169 N·m) @3800 rpm.
A16XER (LDE): 1.6 L (1598 cc): DCVCP, TwinPort, 10.8:1 compression, 116 hp (85 kW) @ 6000 rpm.
Ecotec DCVCP engines are used in:
2005-present Opel Zafira
2007-presentOpel Astra
2008-2009 Saturn Astra (1.8L LUW)
2008-present Chevrolet Cruze (1.8L LUW/2H0)
2009-present Opel Insignia
2012-present Chevrolet Sonic (1.6 L in Europe, 1.8L LUW in North America)
Rozumiem, że mój 1,8 ma III generacji lżejszy blok, zwiększoną kompresję, zmienne fazy rozrządu, zmienny kolektor dolotowy. Produkcja pewnie w Korei.
Coś więcej?
> Coś więcej?
Jak nie ma w Wiki to nie znajdziesz. A szkoda bo to powinno byc na oficjalnej stronie. W domu mam linka wkleje wieczorem powinno byc ciut wiecej info.
