Programowanie pilotow i kody
Ja po siasiedzku tutaj z centomanii, ale do rzeczy. Kolega kupil Fiata Bravo z 2000r, jest w nim fabryczny centralny zamek bez alarmu. Posiada dwa niebieski kluczyki jeden bordowy(z pilotami zintegrowanymi). Posiada takze CODE CARD na ktrej sa dwa kody Eletronic 12345 oraz Mechanical litera1234. Znalazlem na angielskim forum jak programowac piloty ale niestety nie przyjmuje zandego kodu, zielona dioda caly czas sweci po wpisaniu kodu. Moze ktos wie skad wziac prawidlowy kod ale moze jest jakis inny sposob wpisywania. Ponizej zamieszczam instrukcje wedlug ktorej probowal to zrobic:
-Press the button that is between your courtesy light and the ultrasonic sensors on the roof of your car (near sunroof switch)
-nacisnij przycisk i pusc po sekundzie lub dwoch
-Release the button after a second or two
-After a couple of seconds the LED will flash once
-Enter the first digit of your 4 digit code by pressing the button the relevant number of times
-Repeat this for the next 3 digits of the code.
If the code was correct the LED will flash for approximately 10 seconds.
(If the code was incorrect the LED will remain on for 10seconds, so start from the beginning when the LED goes out)
-With the LED flashing press and hold the button on the car and then press and hold the button on the key. Keep them both pressed until the LED stops flashing and remains on.
-Release the button on the remote, then the one on the car.
now what heppens next depends on the age of the car. some cars have a red LED others have a green LED.
for a red LED, if the programming was successful the LED will flash 6 times, but if it was unsuccessful the LED will flash 18 times
for a green LED, if the programming was successful the LED will flash 8 times (i think, maybe less), but if it was unsuccessful the LED will stay on for a few seconds (8 i think?)
> ściągnij sobie opis programowania z kącikowego śmietnika i spróbuj
> wg. opisanej tam procedury
juz znalazlem w smietniku opis, ale obawiam sie ze tego kodu kolega akurat nie posiada. Nie wiecie czy w ASO mozna takie cos dostac i ile moglo by kosztowac. Nie wiem cyz to ma jakies znaczenie ale samochod pochodzi z DE.
w sumie to w czym jest problem , auto nie pali na niebieskich kluczykach ( kod immobilizera ) czy nie działa centralny z pilota w kluczyku ?
> pilota w kluczyku ?
nie dziala centralny z pilota, pali normalnie na wszystkich kluczykach
> kluczykach
podejrzewam że wina leży w centralce zdalnego sterowania, (o ile takowa istnieje) może zasilanie nie dochodzi albo jest ona uszkodzona. A wcześniej działał centralny z pilota??
Wczesniejszego stanu nie znam, ale centralka jest raczej sprawna bo reaguje na przycisk w nia wbudowany tak jak jest to opisane w intrukcje przeze mnie wczensiej zamieszczonej
