custom mustangi
to jeszce pare fotek przerobionych mustangow
GT.500E base
G.T.500E: Base Model
Investment - Starting at $119,000
Motor
* 302 cid Shelby Tuned Small Block, 325 HP
* DC&O Electronic Fuel Injection*
Transmission
* Tremec T5 5-Speed Transmission
Interior
* Shelby Embroidered Signature Black Vinyl Seats
* Shelby Embroidered Hi-Back Bucket Seats, Vinyl*
* Shelby Embroidered Hi-Back Bucket Seats, Leather*
* OEM Lap Seat Belts
* 5 Point Quick Release Harness*
* Shelby Signature Gauges
* 160 MPH Speedometer
* Custom Steering Wheel
* Old Air Products Hurricane A/C System
* CAE Sound Dampening Package*
* Security System*
Stereo System
* Stereo w/CD Player w/4 Speakers
* DVD System with 10 disc DVD Changer*
* 10 Disc CD Changer*
Wheels & Tires
* Shelby or PSE* 17" Wheels
* Rear PSE 17x11 w/ Tubbing*
* BFGoodrich G-Force Tires
* Front: 245/40ZR17
* Rear: 275/40ZR17
* Spare Shelby or PSE Wheel & Tire: 17" X 8" w/Mounting Bracket*
Exterior
* Shelby Emblems
* Functional SC Cobra Style Gas Lid
* Sequential Tail Lights
* Convertible Option*
Fuel
* High Performance Carburetor, Fuel Pressure Regulator & Fuel Pressure Gauge
* Electric Fuel Pump
* High Performance Fuel Filter
* Fuel Cell, 16 Gallons
Rear End
* 31 Spline 9" Posi-Traction TrU Track Differential
* 3.25:1 9" Gears
Steering
* Power Rack and Pinion Steering
Brakes
* Front: Baer 13" X 1.1" Track System, PBR 2 Piston Aluminum
* Rear: 12" X .81" Touring System, PBR 1 Piston Aluminum
* Slotted, Cross Drilled & Zinc Washed
* Adjustable Rear Bias Proportioning Valve
Electrical
* MSD Ignition Control & Coil
* Trunk Mount Battery for Weight Distribution*
Exhaust
* High Performance Headers
* Dual 2.5" Exhaust with "H" Pipe
* 2 1/2" Aluminum Pipe Side Exhaust System w/Tips
Cooling
* Aluminum Cross Flow Radiator
* Spal 16" Electric Cooling Fan, Pull Type
Chassis
* Unique Performance Products Sub-Frame Connector System
* Unique Performance Products Shock Tower Bracing (TB1, TB2 & TB3)
* Drive Shaft Safety Loop
* Roll Bar, 4-Point
Suspension
* Front: Unique Performance Products Coilover
* Rear: QA1 Gas Shocks
* Shelby Style Traction Bars
* Unique Performance Products Rear Coilover*
GT.500E performance
Motor
* 408cid Shelby Tuned Small Block, 475 HP
* 427cid Shelby Tuned Aluminum Small Block, 575 HP*
Transmission
* Tremec TKO 5 Speed Manual Transmission
Interior
* Shelby Embroidered Deluxe Black Vinyl Seats
* Security System*
Stereo
* Stereo with CD Player
Wheels & Tires
* Front: 245/40ZR17
* Rear: 275/40ZR17
Exterior
* Shelby Emblems
Fuel
* Fuel Cell, 22 Gallons*
Rear End
* 31 Spline 9" Posi-Traction Differential
* 3.25:1 9" Gears
Steering
* Bump Steer Adjustable Tie Rods
Brakes
* Vented Air Ducts to Brakes*
Electrical
Exhaust
* 2 1/2" Aluminum Side Pipe Exhaust System w/Tips
Cooling
Chassis
* Roll Bar, 4-Point
Suspension
* Rear: Unique Performance Products Coilover*
GT.500E super snake
Motor
* 427cid Shelby Tuned Aluminum Big Block, FE Engine, 525 H/P
* Shelby Vortech Supercharger, 725 H/P
Transmission
* Tremec TKO 5-Speed Transmission
Interior
* Super Snake Embroidered Hi-Back Bucket Seats, Black Vinyl
* Super Snake Embroidered Hi-Back Bucket Seats, Black Leather*
* G Force 5 Point Quick Release Harness*
* 200 MPH Electronic Speedometer
* LeCarra Wood Trim 15" Steering Wheel
* Security System*
Clutch
* 12 1/2" Diaphragm Clutch
* Tilton Hydraulic Clutch
Stereo System
* Sony Stereo with CD Player
Wheels & Tires
* Front: 245/40ZR17
* Rear: 275/40ZR17
Exterior
* Shelby Emblems
* Super Snake Striping (Thin-Wide-Thin)
Fuel
Rear End
* Currie 31 Spline 9" Posi-Traction Trac-Locker Differential
* 3.25:1 9" Gears
Steering
* Chris Alston Chassisworks Power Steering Rack
* Baer Tracker Bump Steer Adjustable Tie Rods
Brakes
Electrical
Exhaust
* Spin Tech 2.5" Aluminum Mufflers
Cooling
* Griffin Aluminum Cross Flow Radiator
Chassis
* Unique Performance Products Outside Weld-in Sub-Frame Connector
* Unique Performance Products Center Bolt-in Section
* Roll Bar, 4-Point
Suspension
* Rear: Koni Gas Shocks
* Unique Performance Products Rear Coilover Suspension*
GT.500E conwertable
pozdr.
nie , to nie tak
mi tez sie takie maszyny podobaja
> nie , to nie tak
> ale cuz o tych to moge pomazyc
marzenia się spełniają 893goodvibes.gif wszystko zależy od Ciebie waytogo.gif
HanYs
powstawać zaczęły masowo po kinowym "60 sekund"....
"standardowy" GT500 palił 37.5l/100km - ciekawe czy to też "poprawili" wink.gif
> "poprawili"
pewnie tak na 50l/100km
Swietna maszynka, normalnie marzenie
Ogladalem program o tym samochodzie na Discovery Channel i wiem jak sie buduje te samochody od podstaw. Cos pieknego smile.gif i jeszcze na dodatek ten wlasnoreczny podpis Chipa Foose zlosnik.gif
