Może się przyda !
Quote:
Home page - Matthews Volvo Site - Help for Volvo Owners
996 Repair Database entries
147 Volvo Forum users online
VolvoWholesaleParts gives a 5% discount to MatthewsVolvoSite members
IPD Volvo parts specialistsGenuine Volvo parts and accessories
Genuine Used Volvo Parts at Erie Vo-VoFCP Groton
* Home »
o Home Page
o Give Back to MVS
o Help Page
o What's Hot at MVS
o Contact Page
o MVS Philosophy
o MVS Contributor Status
o Opinion Pages
o Volvo ETM Page
* Volvo Forums »
o Register (always free, no spam)
o
o 850, S70, V70, C70 & XC70
o V70, C70, XC70 year 2001+
o S40, V40 & V50
o S60
o S80
o 440, 460, 480
o XC90
o 240, 740, 760, 940, 960, V90
o 120, 130, 140, 164, PV 444, PV 544, Duett, 210, 1800
o
o Opinion
o General Car Talk
o Performance & Mods
o Don's ETM Room
o Classifieds: Volvos & Parts For Sale
* Repair Database »
o Repair Database Overview
o Volvo Repair Categories
o Repairs by Volvo Model
o Everything Alphabetically
o
o Trouble Codes Lookup
o Trouble Codes 1999+
o
o Wiring Diagrams
* Volvo Cars »
o Volvo Cars Overview
o
o Volvo 850
o Volvo V70
o Volvo S40 & V40
o Volvo S60
o Volvo S80
o Volvo XC90
* Volvo Parts »
o Buy Volvo Parts
o Recommended Online Stores
RSS feed for Volvo Blog and Repair Database Follow MVS on Twitter!
Volvo 850, S70, V70, C70, XC70 Trouble Codes
Up to/including Model Year 1998
Please help us add to this by posting your additions to this topic. Looking for 1999+ model trouble codes?
On Board DTC (850) Generic OBD Code Volvo OBD Code Meaning of Code Repair/Info Location (850, 1st Gen 70 Series) Repair Info/ Location (1st Gen S/V40 &50’s) Repair/ Info Location (P2 Cars)
A-1 Transmision
111 No faults found
112 Solenoid S1 short circuit to battery voltage
113 Transmission control module (TCM) fault
114 Program selector open circuit or short circuit to supply
121 Solenoid S1 short circuit to ground or control module fault
122 Solenoid S1 open circuit
123 [something] Solenoid STH short circuit to battery voltage viewtopic.php?t=16229
viewtopic.php?p=63292
124 Mode selector faulty or short circuit to ground
131 Solenoid STH open/short circuit or control module fault
132 Transmission control module(TCM) fault
134 Faulty load signal from ignition control module
141 Oil temperature sensor short circuit to ground
142 Oil temperature sensor open circuit
143 Kickdown switch faulty or short to ground
211 Transmission control module (TCM) fault
212 S2 solenoid short circuit to battery
213 Throttle position (TPS) signal too high
221 S2 solenoid short circuit to ground or control module fault
222 S2 solenoid open circuit
223 Throttle position (TPS) sensor signal too low
231 Throttle position (TPS) sensor sporadic
232 Speedometer signal missing
233 P0500 Incorrect speedometer signal viewtopic.php?f=1&t=17383
235 High Oil temperature
245 Open or short in Torque limiting circuit
311 RPM signal from transmission missing
312 RPM signal from transmission faulty
313 Faulty signal from gear position sensor (PNP)
321 Shift time too long
322 Incorrect gear ratio
323 Lock up slips or is not engaged
331 Short circuit to battery in SL circuit
332 SL solenoid open or control module fault
333 SL solenoid short or control module fault
A2 – Fuel System
111 No faults detected
112 Fault in ECM
115 P0201 Injector 1
121 P0102 (low), P0103 (high) MAF sensor signal
123 P0117 (low), PO118 (high) ECT signal
125 P0202 Injector 2
131 RPM sensor signal missing
132 Battery voltage
135 P0203 Injector 3
143 P0326 Front knock sensor signal
145 P0204 Injector 4
153 P0136 (faulty), P0137(low), P0138 (high) Rear HO2S signal
154 P0402 EGR system leakage
155 P0205 Injector 5
212 P0130 (missing/faulty), P0131 (low), P0132 (high), P0133
(slow) Front HO2S signal
214 P0336 RPM sensor signal sporadic
223 P1505 (low), P1506 (high) IAC valve opening signal
225 A/C pressure sensor signal
231 P0171 (part load), P0172 (part load) Long term fuel trim, part load P0172 code broken elbow
232 P0171 (lower limit) Long term fuel trim, idling
233 P0172 (part load & upper limit) Long term idle air trim P0172 code broken elbow
241 P0400 EGR system flow malfunction
245 P1507 (low), P1508 (high) IAC valve closing signal
311 VSS signal
314 CMP sensor signal
315 P0440 EVAP system
325 Memory failure
335 P1617, P1618 Request for MIL lighting from TCM /viewtopic.php?f=1&t=27973
411 P0122 (low), P0123 (high) TP sensor signal
413 P1416 (Faulty), P1417 (Low), P1418 (High) EGR temp sensor signal
414 Boost pressure reduction from TCM
416 Temperature warning level 1
432 P0331 Rear knock sensor signal
433 P0331 Front HO2S slow response
435 P0133 (slow), Front HO2S slow response
436 Rear HO2S compensation
443 P0422 Three way cat. Efficiency /forums/viewtopic.php?f=1&t=22996
California emissions test with p0422 and p1171
444 P1307 (low), P1308 (high) Acceleration signal
451 P0301 Misfire cylinder 1
452 P0302 Misfire cylinder 2
453 P0303 Misfire cylinder 3
454 P0304 Misfire cylinder 4
455 P0305 Misfire cylinder 5
513 P1405 Temperature warning level 2
514 Engine cooling fan low speed signal
521 P0135 (low/high) Front HO2S Preheating
522 P0141 (low/high) Rear HO2S Preheating
531 P1101 Power stage group A
532 P1102 Power stage group B
533 Power stage group C
534 Power stage group D
535 TC control valve signal
541 P0444 (low), P0445 (high) EVAP valve signal
542 P0300 Misfire more than one cylinder
543 P1310 Misfire at least one cylinder
544 P0300 Misfire more than one cylinder, three way cat damage
545 P1310 Misfire at least one cylinder, three way cat damage
551 P0301 Misfire cylinder 1, three way cat damage
552 P0302 Misfire cylinder 2, three way cat damage
553 P0303 Misfire cylinder 3, three way cat damage
554 P0304 Misfire cylinder 4, three way cat damage
555 P0305 Misfire cylinder 5, three way cat damage
A3 – ABS
111 No DTC set
121 Left front wheel sensor, faulty signal <40 km/h
122 Right front wheel sensor, faulty signal <40 km/h
123 Left rear wheel sensor, faulty signal <40 km/h
124 Right rear wheel sensor, faulty signal <40 km/h
125 Signal faulty from at least one wheel sensor for a long period
135 Control Module faulty
141 Faulty pedal sensor, shorted to ground or supply
142 Faulty brake pedal switch, open or short
143 Control module faulty
144 Brake discs overheated
151 Left front wheel sensor, open/short to battery
152 Right front wheel sensor, open/short to battery
155 Rear axle sensor open/short to battery
211 Left front wheel sensor, not signal on moving off
212 Right front wheel sensor, no signal on moving off
213 Left rear wheel sensor, no signal on moving off
214 Right rear wheel sensor, no signal on moving off
215 Valve relay, open/short
221 Left front wheel sensor, ABS operation signal missing
222 Right front wheel sensor, ABS operation signal missing
223 Left rear wheel sensor, ABS operation signal missing
224 Right rear wheel sensor, ABS operation signal missing
231 Left front wheel sensor, signal missing
232 Right front wheel sensor, signal missing
235 Rear axle sensor, signal missing
311 Left front wheel sensor, open/short
312 Right front wheel sensor. open/short
313 Left rear wheel sensor, open/short
314 Right rear wheel sensor, open/short
321 Left front wheel sensor, irregular >40 km/h
322 Right front wheel sensor, irregular >40 km/h
323 Left rear wheel sensor, irregular >40 km/h
324 Left rear wheel sensor, irregular >40 km/h
411 Right rear wheel sensor, irregular >40 km/h
412 Left front wheel inlet valve, open/short
413 Left front wheel return valve, open/short
414 Right front wheel inlet valve, open/short
415 Rear valve open/short
421 Right front wheel return valve, open/short
422 Rear wheel return valve circuit, open/short
423 Traction control system valve, open/short
424 Pressure switch for TRACS, faulty or short circuit
441 Control module faulty
442 Pump pressure low
443 Pump motor, electrical or mechanical fault
444 No power supply to valves in hydraulic unit
A6 – Ignition
111 No DTC set
112 Control Module fault
123 Engine Coolant Temperature Sensor (ECT) from Control module
missing or faulty
131 Engine speed (RPM) sensor signal missing
142 Control Module Fault
143 Knock sensor (KS) missing or faulty
144 Ignition control module load signal missing
154 EGR system flow too high in system
214 Engine speed (RPM) sensor signal missing sporadically
224 Engine Coolant Temperature sensor (ECT) signal missing or
faulty
234 Throttle Position (TPS) signal missing at idle
241 EGR system flow too low in system
243 Throttle Position sensor (TPS) signal missing at idle
311 Vehicle speed signal missing or faulty
314 Camshaft Position sensor (CMP) signal missing or faulty
324 Camshaft Position sensor (CMP) signal missing sporadically
411 Throttle position sensor (TPS) signal from fuel injection
system missing or faulty
413 EGR temperature sensor signal faulty
432 Control module box temperature too high level 1
433 Knock sensor (KS) signal missing or faulty
513 Control module box temperature too high, level 2
A7 – Combined Instrument (Trip
Computer)
112 Fuel gauge short circuit
113 Fuel gauge open circuit
121 Temp. sensor interval too short
122 Temp. sensor interval too long
123 Digital output 48 pulse short circuit to supply
131 Digital output 12 pulse short circuit to supply
132 No RPM sensor signal
133 Tank signal to trip computer short to supply
B1 Electronic climate control
111 No fault
121 Outside temperature sensor shorted to ground
122 Outside temperature sensor open circuit or shorted to 12 volts
123 Driver’s side interior temperature sensor shorted to ground
124 Driver’s side interior temperature sensor open circuit or
shorted to 12 volts
125 Passenger’s side interior temperature sensor shorted to
ground(earth)
126 Passenger’s side interior temperature sensor open circuit or
shorted to 12 volts
131 Driver’s side air duct temperature sensor shorted to
ground(earth)
132 Driver’s side air duct temperature sensor open circuit or
shorted to 12 volts
133 Passenger’s side air duct temperature sensor shorted to
ground(earth)
134 Passenger’s side air duct temperature sensor open circuit or
shorted to 12 volts
135 No signal from engine coolant temperature sensor
141 Faulty signal from driver’s side temperature selector switch
143 Faulty signal from passenger’s side temperature selector
switch
145 Faulty signal from function selector switch
151 Signal from fan speed sensor missing or too high
152 Signal from fan speed sensor shorted to earth
211 Driver’s side damper motor position sensor open circuit or
shorted to 12 volts
212 Driver’s side damper motor position sensor shorted to earth
221 Passenger’s side damper motor position sensor open circuit or
shorted to 12 volts
222 Passenger’s side damper motor position sensor shorted to earth
231 Ventilation damper motor position sensor open circuit or
shorted to 12 volts
232 Ventilation damper motor position sensor shorted to earth
233 Floor/defrost damper motor position sensor open circuit or
shorted to 12 volts
234 Floor/defrost damper motor position sensor shorted to earth
235 Recirculation damper motor position sensor open circuit or
shorted to 12 volts
236 Recirculation damper motor position sensor shorted to earth
311 Driver’s side damper motor shorted to earth or shorted to 12
volts
312 Passenger’s side damper motor shorted to earth or shorted to
12 volts
313 Ventilation damper motor shorted to earth or shorted to 12
volts
314 Floor/defrost damper motor shorted to earth or shorted to 12
volts
315 Recirculation damper motor shorted to earth or shorted to 12
volts
321 Driver’s side damper motor active too long
322 Passenger’s side damper motor active too long
323 Ventilation damper motor active too long
324 Floor/defrost damper motor active too long
325 Recirculation damper motor active too long
411 Blower fan seized or drawing excessive current
412 Driver’s side interior temperature sensor inlet fan shorted to
earth
413 No control voltage at driver’s side interior temperature
sensor inlet fan
414 Driver’s side interior temperature sensor inlet fan seized
415 Passenger’s side interior temperature sensor inlet fan shorted
to earth
416 No control voltage at passenger’s side interior temperature
sensor inlet fan
417 Passenger’s side interior temperature inlet fan seized
418 No control signal to blower fan power stage
419 Faulty diagnostic signal from blower fan power stage
420 ECU fault in program memory
511 Damper motor limit position self-adjustment not carried out
B2 – Cruise Control
112 Abnormal speed signal
122 Speed has not exceeded 22mph or no speed signal (not a code
to worry about)
211 Control module malfunction
212 Malfunction in the circuit to the vacuum pump or regulator
B5 –SRS
111 No fault detected
112 Sensor module fault
127 SRS lamp open/short circuit
211 Drivers airbag short circuit
212 Drivers airbag open circuit
213 Drivers airbag short circuit to ground
214 Drivers airbag short circuit to supply
221 Passenger airbag short circuit
222 Passenger airbag open circuit
223 Passenger airbag short circuit to ground
224 Passenger airbag short circuit to supply
231 Left belt tensioner short circuit
232 Left belt tensioner open circuit
233 Left belt tensioner short circuit to ground
234 Left belt tensioner short circuit to supply
241 Right belt tensioner short circuit
242 Right belt tensioner open circuit
243 Right belt tensioner short circuit to ground
244 Right belt tensioner short circuit to supply
Fenix 5.2 System (only on some 850’s)
112 ECU fault
113 Short term fuel mixture too weak
115 Faulty signal to no 1 cylinder injector
121 MAP sensor signal absent or faulty
122 Intake air temp sensor signal absent or faulty
123 Coolant temp signal absent or faulty
125 Faulty signal to no 2 cylinder Injector
132 Battery voltage too low or too high
135 Faulty signal to no 3 cylinder Injector
143 Front knock sensor signal absent or faulty
144 Load signal absent or faulty
145 Faulty signal to no 4 cylinder Injector
152 Air pump signal absent or faulty
154 EGR system leakage
155 Faulty signal to no 5 cylinder Injector
212 Heated oxygen sensor signal absent or faulty
214 RPM sensor signal absent
221 Long term fuel mixture too weak in part load stage
222 Main relay signal absent or faulty
223 Idle air control valve signal absent or faulty
225 A/C pressure sensor signal absent or faulty
231 Long term fuel mixture too rich in part load stage
232 Long term fuel mixture too weak at idle
233 Long term idle air trim outside control range
235 EGR controller signal absent or faulty
241 EGR system flow fault
243 Throttle position sensor signal outside voltage range
244 knock control at limit
311 Vehicle speed sensor signal absent(speedometer)
313 Evap valve signal absent or faulty
314 Camshaft position sensor signal absent or faulty
323 Malfunction indicator lamp signal faulty
325 Ecu memory loss
335 Request for malfunction indicator lamp from automatic
transmission ECU
342 Air conditioning system relay control signal faulty
343 Fuel pump relay control signal faulty
411 Throttle postion sensor signal outside voltage range
413 EGR temp sensor signal absent or faulty
432 High temp in ECU module box
433 Rear knock sensor signal absent or faulty
435 Heated oxygen sensor slow response
442 Air pump relay signal absent or faulty
511 Long term fuel mixture too rich at idlel
512 Short term fuel mixture too rich
513 Excessively high temperature in ECU module box
514 Engine cooling fan faulty at half speed
515 Engine cooling fan faulty at full speed
521 Oxygen sensor heating faulty
523 Signal to ECU module box cooling fan shorted to 12 volts
524 Transmission torque control signal faulty
535 Turbo regulator valve fault
Motronic 4.3 (Only on some 850’s)
112 ECU fault
121 MAF sensor signal absent or faulty
131 Engine speed (RPM) sensor signal absent or faulty
223 Idle air control valve siganal absent or faulty
244 Knock control at limit
245 Idle air control valve closing signal absent or faulty
315 Evap system fault
325 Ecu memory loss
transmission ECU
414 Turbo boost pressure too high
416 Turbo boost pressure reducsed by automatic transmission ECU
524 Transmission torgue control signal faulty
541 Evap fault
Jetronic LH3.2 (Only certain early 850’s)
112 ECU fault
411 Throttle postion sensor signal absent
* Digg
* del.icio.us
* Facebook
* Google Bookmarks
* email
* StumbleUpon
* Twitter
Browse Repair Database
volvo reliability S70 XC70 C70 740 Tutorial ETM S80 V70 XC 960 Performance & Horsepower S60 240 940 760 850 V70 XC90 S40 Timing Belt
These are only a random 20 of the hundreds of topics covered in our repair list.
Or Search for Your Repair
See the Repair Database categories »
...find Volvo information if you're looking for a specific maintenance topic, like transmission / CV help.
Or Search for Your Model
See the Repair Database by Volvo model »
...find Volvo information if you're looking for something specific to your Volvo car, like Volvo V70 / S70 maintenance.
Help Make MVS Even Better
The more donations and revenue I receive, the more work I can do here. With all the donations and sponsor support in the last year, I've been able to do more work than the previous five years combined. Keep it up!
Donate
MVS Donations (what do I do with donations?)
Amazon.com link
Amazon.com - MVS link Click that before you add items to your cart and it helps this site. Because this site is in the Amazon Associates program, I get a small % of your purchase total when the items ship to you. It's free and transparent to you, and it's an Amazon program so there's no funny business going on, no third party.
Tire Rack link
See TireRack's Latest Deals and this site gets a payout if you buy tires or wheels.
Dunlop $50 Rebate
Link to us
Link to us on your website or blog.
Many Thanks to...
IPD, MyVolvoPartsOnline, FCP Groton, Erie Vo-Vo and Volvo Wholesale Parts
Thanks very much - Matt
The Volvo Repair Database and some other pages are proudly powered by WordPress Entries (RSS) and Comments (RSS).
12424360 "
