Moja miłość
piękny przykład brytyjskiego roadstera...
samochód z jaszczurka na masce:
piękny przód:
równie piękny tył:
wnętrze zapierające dech w piersiach:
jest też wersja zamknięta:
i z tyłu:
i jeszcze kilka zdjęć:
DANE TECHNICZNE - roadster:
MF 3
BODY high-quality, glass fibre reinforced composite material
ENGINE BMW 6-cylinder in-line engine – Capacity 3.246 cm3
Rated power/rated speed 252 kW / 343 PS / 7.900 rpm
max. torque/speed 365 Nm / 4.900 rpm
FUEL CONSUMTION* Urban 17,8 l / 100 km - Extra-Urban 8,4 l / 100 km
Combined 11,9 l / 100 km
Co2-EMISSIONS Combined 287 g / km
TRANSMISSION 5-speed manual gearbox, if desired 6-speed
or 6-speed sequential (SMG II)
POWER TRAIN Rear wheel drive
DRIVING PERFORMANCE Maximum speed: 255 km/h -
Acceleration: 0-100 km/h: 4,9 sec.
TIRES Basic equipment front 215/50 ZR 17 ­ rear 215/50 ZR 17 to
front 235/30 ZR 20­ rear 285/25 ZR 20 (special equipment at an extra charge)
WHEEL SUSPENSION MacPherson strut front suspension with transverse link, stabilizer
Central control arm rear axle with leading and transverse link,
stabilizer
WEIGHT 1.180 kg
DIMENSIONS Length: 3,86 m / Width: 1,75 m / Height: 1,16 m
DANE TECHNICZNE - coupe:
WIESMANN GT MF 4
CHASSIS Aluminium
BODY High-quality, glass fibre reinforced composite material
ENGINE BMW V 8 – Capacity 4.799 ccm
Rated power/rated speed 270 kW/367 PS / 6,300/rpm
max. torque/speed 490 Nm / 3,400 rpm.
FUEL CONSUMTION* Combined 11,7 l / 100 km - Extra urban17,2 l / 100 km
Urban 8,6 l / 100 km
Co2-EMISSIONS Combined 267 g / km
GEARBOX 6-speed manual gearbox
POWER TRANSMISSION Rear wheel drive
PERFORMANCE Maximum speed: 290 km/h – Acceleration: 0-100 km/h: 4,6 sec.
TYRES front 245/45 x 18 - 245/35 x 20, rear 245/45 x 18 - 275/30 x 20
WHEEL SUSPENSION
Single wheel suspension front and rear
front: aluminium double transverse link
rear: aluminium double transverse link with trailing link
WEIGHT 1.280 kg
DIMENSIONS Length: 4,22 m / Width: 1,86 m / Height: 1,22 m
LINK do strony producenta
Żadna nowość ale autko naprawde kozak:)
Takie same białe jak na zdjeciu stało w lipsku na targach na żywo rewelacja auto smile.gifsmile.gif
  • 2 miesiące później...
Oj można sie zakochać
Pomijajac kolor skory kierownice ma identyczna jak Uno Abarth rotfl.gif.
  • 3 tygodnie później...
> Pomijajac kolor skory kierownice ma identyczna jak Uno Abarth .
Chyba jak BMW ?! Mam taka samą w e46, manetki od kierunków i wycieraczek rownież. Tak samo kluczyk - wyraznie widac kształt kluczyka bmw
a co powiesz na tak wykończoną wersję 270751858-jezyk.gif270751858-jezyk.gif270751858-jezyk.gif ??
szczerze to brzydsiejszego samochodu dawno nie widzialem :/
juz predziej countach jak ten wybryk natury
Skoro tak to dla przypomnienia:
proszsz:
A Wiessman wcale nie jest taki brzydki
wedlug mnie nawet to wyglada lepiej
> pfff, nawet multipla wyglada lepiej
> w takim razie gratuluje dobrego smaku
zgadzam sie ze te auta sa brzydkie/koszmarne zlosnik.gif
przykro mi jest tylko osoby, ktora zalozyla temat "Moja milosc"
moja miloscia np jest f355 gts, toyota mr2 mk2 gt t-bar, fiat coupe 2.0 20vt+ czy 512tr wink.gif
> 2.0 20vt+ czy 512tr
jesli chodzi o 512 tr ...zgadzam się z Tobą w 100% - zajebisty jest claps.gifclaps.gif
> Chyba jak BMW ?!
Wracając do fotek, które podałeś wcześniej to wygląda to dla mnie na kiepski VT patrząc przynajmniej na dźwignię zmiany biegów i prześwietloną całość.
> A ponoć o gustach się nie dyskutuje
> Nie, jak w Uno
Szkoda, że kiera z abartha jest równie deficytowym towarem jak ta z WIESMANN'a bo można by zarobić trochę 270751858-jezyk.gif
A może jakiś inny producent ekskluzywnych aut wyposażał swoje samochody w kierownice podobne do takich jakie są spotykane w mniej ekskluzywnych autach?
> Na przykład w Polonezie
Z tego co pamietam taka sama kierownice jak ta abarthowska mial prototyp Caro Plus z deska rozdzielcza zaprojektowana prze Polakow (przed przejeciem przez DajEwo). Nie mam foty na laptoku ale jak znajde to podrzuce ok.gif.
> ale jak znajde to podrzuce .
