Komuś w Infiniti odbiło
Florydzialski
> Od modelu 2014 wszystkie Infiniti bedą sie nazywały Qcośtam. Obecne G37 bedzie Q50, G37 Coupe
> bedzie Q60 a M37 stanie sie Q70.
A ktoś tę Q qpuje?
Na rynku EU jakoś się chyba ta marka nie przyjęła. W PL ceny są chore.
Pozdro
Bartek
Infiniti już wyjaśniło zmiany. Najbardziej interesujący jest punkt 2:
Quote:
We love you dearly. And we know you love the brand. Which means it’s only natural that you may feel surprised by the announcement that we plan to change our nomenclature philosophy. No one likes change.
It was a tough decision, we like our current model names as much as you do. But we had no choice but to change. Let me explain.
1. We are embarking on a massive product offensive, and these new cars need names. There are no suitable combinations of Alphanumeric naming options remaining which are not already trademarked by another automaker. In order to expand our line up with the fascinating new models we are developing, we must create a more flexible nomenclature philosophy.
2. Our new advanced technology engines under development will be smaller, lighter, more fuel efficient yet more powerful. And we will introduce some exhilarating performance machines in the future. I'm sure you will agree, it would be a bit odd to have a powerful, luxurious and refined V8 powered Infiniti M56, then position a new high-tech 550+ horsepower performance flagship for the Infiniti M range above it, using a potent charged induction V6, but then call it Infiniti M30, which we would be obliged to do, following our current naming logic.
3. Infiniti is becoming a global brand now, we are already active in almost 50 countries, the majority only very recently. Our new customers are unfamiliar with the brand and struggle to understand our range hierarchy. Is a JX above or below an FX? Where does an EX fit? What is the relationship between G and Infiniti M? Research confirms the majority of newcomers to our brand consider the naming to be somewhat arbitrary and confusing.
4. Infiniti owns the naming assets of Q plus double digit, and QX plus double digit. And it is a permanent part of our heritage.
So the solution is pretty straightforward - use Q for cars, QX for crossovers, and double digits in increments of ten, to denote hierarchy, linked to the price point of the model, not size and not engine displacement. And no, we won’t call all-wheel drive models Q50X or QX50X. The fact that a model may feature four wheel drive, will be indicated by specific badging describing this feature on the car, and is not part of the model name.
The really exciting implication of all this, is that it prepares the way for the introduction of several fascinating new models, above and below the current line up, a wider range of powertrains, including some truly stunning performance cars in our future.
So there is only good news for all Infiniti fans around the globe. We are working very hard to bring you great products, a great brand and a compelling ownership experience. And we are really confident you will love the new Q50. It's simply that good.
Warmest regards
Johan de Nysschen
President
Infiniti Motor Company Limited
> To moze napisz ten drugi punkt, a nie wklejasz cos w obcym jezyku.
ok jasne, więc w wielkim skrócie i uproszczeniu:
1. Infiniti chce rozszerzyć palete modeli i obawia się, że nie będzie już pasujących literek które nie są zastrzeżone/kojarzone z innymi markami
2. Chcą pozbyć się oznaczenia silnika z nazwy ponieważ planują wprowadzenie nowych silników: lżejszych, bardziej ekonomicznych i mocniejszych. Jako przykład podano obecny flagowy produkt M56 z bardzo mocnym silnikiem V8 i gdyby zachować aktualne nazewnictwo to nowa flagowa limuzyna z silnikiem V6 i mocą 550+ musiałaby się nazywać M30. Punkt ten daje sygnał, że w nowych silnikach możemy spodziewać się już turbo i zapewne hybryd, co jest bardzo dobrym krokiem, szczególnie patrząc na aktualne m35h, które rozpędza się szybciej niż moje g37, a spala połowe tego co mój samochód.
3. Takie pierdu pierdu - że infiniti to globalna marka i klieci pogubili się z aktualnym nazewnictwem. Nie potrafią pozycjonować poszczególnych modeli infiniti: czy Qx jest lepsze niż FX, jak ma się do tego np JX itp.
4.Nazewnictwo zmienia się na Q[dwie cyfry] dla sedanów i QX[dwie cyfry] dla modeli typu suv/crossover Nie będzie dodatkowych oznaczeń (np QX50X) dla modeli z np napędem na 4 koła itp. Będzie to sygnalizowane osobnym napisem (coś jak quattro w audi). Dzięki tej zmianie będzie można dodać do listy modeli kilka samochodów pozycjonowanych wyżej i niżej niż aktualne - oznacza to wprowadzenie czegoś mniejszego niż G
Generalnie wpis ten sugeruje, że infiniti mocno uderzy w przyszłym roku - odświeżone aktualne modele, zupełnie nowe modele, nowe mocniejsze i bardziej ekonomiczne silniki. Zapowiada się fajna walka w klasie lexus/bmw/audi/mercedes
A premiera pierwszego modelu z zmianami już 14 stycznia - wtedy pokazany zostanie następca obecnego G37 sedan.
> Akurat "Q" na początku to się kojarzy z Awdi Przynajmniej mi
A poważnie to Ford w ten sposób prawie wykończył Lincolna - nagle w salonach mieli identyczne samochody z których część miała napis Zephyr a cześć MKZ. Zephyry trzeba było sprzedawać z olbrzymim upustem, co spowodowało ze klienci zaczęli patrzeć podejrzliwie na markę. To samo stanie sie z Infiniti - obecne G37 Coupe bez żadnych zmian stanie się Q60 = u dealera bedą modele z jedna i druga nazwą = G37 bedzie pewnie miało zniżki po $10K na sztuce. To sie od razu odbija na wartości odsprzedażnej samochodu i alienuje to obecnych właścicieli.
> To samo
Bez przesady, przelepią znaczki i przedrukują instrukcje. Nie jest
to chyba zabronione?
